The painters on our job finished the VA fir trim with a sprayed-on lacquer, on top of a sanding-sealer, in their shop. The finish is really soft; it takes almost nothing to scratch through the finish. For example, I left a scratch in a test piece with my fingernail and the nail’s soft – I’ve been chewing on it worrying about the finish. Anybody got a recommendation on how to go from what we’ve got to a more durable finish? The casings, head casings, and baseboard are already installed…
Regular nitrocellulose lacquer dries very quickly to the touch, but it takes much longer to cure and fully harden. There are all kinds of variables--how thick the film was laid on, how many coats were applied, the temperature and humidity levels before and after application, whether a retarder was used to thin it, etc. Give it a couple of weeks and you should notice a big difference in the surface hardness of the lacquer film. If they laid on a really thick coat, give it a month.
Catalyzed lacquers are another beast altogether. If that's what they used, they may not have mixed the correct ratio of catalyst to finish, in which case you're up a creek.
Regular lacquer will melt with lacquer thinner but cat. lacquer will not.. Fir is a little soft & lacquer will not change that..
*Hi Steve:In the furniture finishing biz, putting a hard finish over a soft one is a big no-no. I'd resist the temptation to try to 'protect' this finish. Jed's right - finish can take a good time to reach final hardness. Both the external moisture and the internal moisture (i.e. the wood itself) will affect the drying rates as well as ambient temperatures. I usually try to wait two weeks to a month before rubbing out any finish. You should be thinking along the same lines.-t
*L.Siders,
View Image © 1999-2000"But, some people without brains do an awful lot of talking. . ." The ScareCrow
The painters on our job finished the VA fir trim with a sprayed-on lacquer, on top of a sanding-sealer, in their shop. The finish is really soft; it takes almost nothing to scratch through the finish. For example, I left a scratch in a test piece with my fingernail and the nail's soft - I've been chewing on it worrying about the finish. Anybody got a recommendation on how to go from what we've got to a more durable finish? The casings, head casings, and baseboard are already installed...
