green- the color not the technique- plum
I have a “in the wall” laundry box to feed and drain my washing machine. The hot and cold shut off is a single lever between the two hose thread fittings. I believe it is brass. It has a green corrosion on it and looks like heck. Any easy way to remove this corrosion with-out damaging the plastic box? Thanks for any input.
http://www.doityourself.com/stry/brass
Get some "Brasso" polish. Commonly found at most stores, even in the cleaning supplies at groceries. Make sure to shake it well. Apply it then scrub with a toothbrush. If you work at it long enough it will be polished, but it will take off the green corrosion very fast.
''Brasso'' is an interesting product. In the old days those who were desperate enough would filter the polish through a slice of bread and drink the alcohol.
Brown sauce, we have a brand over here called 'HP' , is also useful for cleaning metal and I'm told that Coca Cola syrup will clean almost anything.
Coke contains the same acid that is active in Naval Jelly for rust removal
MmmmmmA nice cold bottle of naval jelly would hit the spot right about now...;o)
A man, convinced against his will...
Is of his own opinion, still.
~Anne McCaffrey
Use the same stuff you use to polish the refridgerator feet and the garbage disposal caseing.
~Anne McCaffrey
Already tried all the obvious fixes, Duh!
What Luka's trying to say is that it's a friggin' laundry shutoff, not the queen's tea service. Just wipe it down with a damp rag occasionally, to remove the detergent residue that causes the discoloration.But if you absolutely must get it clean, try toothpaste and an old toothbrush.
The queen's tea service. Good one ! Wish I'd thought of it.=0)
~Anne McCaffrey
Tomato sauce or Kool-aid and a toothbrush. Really.
paint the walls to match. verdigris is "in"
