In the upcomming pictures you will see some rough plumbing repairs on my “new” home that is under construction. After the rough plumbing got the OK before the concrete pour, this is what Lot 3 ended up with in one of my bedrooms. A supply line and a sewer drain under the window a foot into the room. No one would tell me what the story was. Today I found out. It was suppose to come up under the wall to supply a sink in the laundry room. What are your thoughts on what Centex is doing. There will only be 3/8 inch of concrete above the sewer pipe next to the wall and a supply line under pressure following it. GW
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
In the upcomming pictures you will see some rough plumbing repairs on my "new" home that is under construction. After the rough plumbing got the OK before the concrete pour, this is what Lot 3 ended up with in one of my bedrooms. A supply line and a sewer drain under the window a foot into the room. No one would tell me what the story was. Today I found out. It was suppose to come up under the wall to supply a sink in the laundry room. What are your thoughts on what Centex is doing. There will only be 3/8 inch of concrete above the sewer pipe next to the wall and a supply line under pressure following it. GW
