hi all, Igot the grex 635 pinner in july its been nothing but problems. now i broke the driver blade. i’ve been looking online but i can’t seem to find parts for this thing.
There's a constant source of clean water for you to use, and all you have to do is collect it.
Did ya try toolpartsdirect.com?
Also, I think the Cadex is the same gun, but not 100% it may be the Nikle that is the clone. Good luck.
shpere, thanks for the suggestion but I tried them no deals
- couchcarp -
Try this yet?
Grex Replacement Parts
Our Mission | Micro Pinner | 23 Gauge Micro Pinner & Pins | Grex P650 | Grex P645 | Grex P635 | Grex P630 | Grex Reviews | Grex Replacement Parts | 23 Gauge ...thefastenercompany.com/grex_replacement_parts.htm - 41k - <!---->Cached - Similar pages<!---->Spheramid Enterprises Architectural Woodworks
yep this place has it . 30 bucks, my comp is not lettin me buy it now but i will latter, thanks for the tip.
since i'm on the subject does anyone else use these things in finish carpentry? I'm not talking shop work or kitchens but regular dirty finish work with dust an inch thick everywhere and occasionally draging it buy the hose and general abuse.
Who'd you get the gun from?
Is there no manu. warranty over 6 months?
http://www.quittintime.com/
calvin I got the gun from woodcraft. dont know about warranty as it may have been my stupidity that broke the driver. the reason i said its been a problem is after shooting a dozen or so pins the tip of the driver would mushroom over then get hung up when i fired it. take the nose piece off manually push the driver back then it would be good to go for another 4-5 pins. this got old real fast. my solution was to file off the burr. this worked ok but needed to be done often. a couple weeks ago i'm pinning crown together and i'm in a hurry when it starts giving me trouble, so I decide since the driver is so soft instead of comming down finding a file etc; I would just flatten it back out with my hammer.it snapped of about a quarter inch with just 1 very light tap.
broken driver...........you watching the air pressure going in?
[email protected]
air pressure about 90 pounds read my description of how I broke it,pretty stupid I know.
Try this guy. I bought my gun from him at the woodworking show last year. He should be able to help. Super nice guy and great tool.
http://www.jerrycarterairtoolsupply.com/
John
J.R. Lazaro Builders, Inc.
Indianapolis, In.
You should definitely call Jerry Carter, as posted above. I was doing a search for his name in my contacts when I noticed John L. beat me to it. I had some problems with a Grex pinner and Jerry took care of me.
Jon Blakemore
