hand rail bracket over drywall screw
fossil | Posted in Construction Techniques on May 10, 2005 08:15am
I managed to locate a hand rail bracket directly over a drywall screw beneath.  The top hole on the left of a three hole bracket.
You think I should try to drill it out with a 1/16″ bit and work my way up to a bit just shy of the screw thread diameter or?
I’d move it over a hair, but figure I’ll miss the stud with one of the screws.
Thanks for any suggestions.
  1. Gumshoe | May 10, 2005 08:19am | #1
    Remove the drywall screw.
    1. fossil | May 10, 2005 08:25am | #3
      That sounds pretty simple.  I figured I would damage the texture and paint beyond the edge of the bracket if I tryed.
        IMERC | May 10, 2005 08:27am | #4
        score the head of the screw and remove the mud over it before you pull the screw...
        WOW!!!   What a Ride!
        Forget the primal scream,  just ROAR!!!
      2. Gumshoe | May 10, 2005 08:33am | #5
        A.) What IMERC said.
        B.) You gotta break a few eggs to make an omelette.
        1. fossil | May 11, 2005 02:55am | #6
          I eat 56 eggs a week,
  2. mikeys | May 10, 2005 08:20am | #2
    I think that since the dw screw is so accurately located I'd just back it out. You'll have missing mud the size of the screw head and if the bracket doesn't completely cover it it's a very minor repair.
    Smile. It could be worse. You could be me working for you.
  • Sharp-Blade Solution
