I am needing to install several stainless steel bars in an existiing ceramic tile shower. Anyone have any suggestions re: drilling 12+ holes thru ceramic tile and what kind of fasteners to use in this situation w/no blocking, probably installed over “greenboard” and waterproofing this installation? Randy Shaum
Structural steel and strong connections help a raised floor resist high winds and water.
In a Fine Homebuilding Kitchen & Bath (issue #135, page # 112)they tested a grab bar anchor desined for tile walls.
http://www.wingits.com
Terry
*Use toggle bolts, they should be plenty strong. I've never had a call back on any I've installed Drill the appropriate size holes with carbide masonry bits and a hammer drill. If the toggle bolt head is exposed on the bar flange, make sure you use stailess steel or brass bolts. John
*Definatly the toggle bolts , and use the good ones not the little wimpy ones
I am needing to install several stainless steel bars in an existiing ceramic tile shower. Anyone have any suggestions re: drilling 12+ holes thru ceramic tile and what kind of fasteners to use in this situation w/no blocking, probably installed over "greenboard" and waterproofing this installation? Randy Shaum
