I have a new house with sheetrock attached to metal studs. I am planning to hang 30″ H x 24″ W x 12″ D wood upper cabinets for a home office. Are the metal studs strong enough to hold the cabinets? Is there anything special I need to consider when planning this job? Thanks for your help
Generally,The metal studs will hold ok
Use proper length sheet metal screws... #12 ... with washers
For added support under, you could install a small horizontal ledge... 3/4" quarter round.
Edited 1/26/2005 1:23 pm ET by Hube
Thanks!
Blocking between the studs!!!???
putting a ledge under them would give exactly the same benefit as putting one more screw in each stud.
Mr T
I can't afford to be affordable anymore
Thanks!
When I was an apprentice carpenter I had an instructor who insisted metal studs held a screw better than a wood stud. I challenged his theory and he proved me wrong.
Just dont over drive the screw to the point where you strip the hole
Welcome to BT, first off!
Yep, bunches of them out there in commercial work.
Finding the studs accurately, is the biggest thing. Even with a self-drilling, self tapping, screw (what you should use for hanging-IMHO), hitting the edge of a stud is an unpleasant experience.
A screw through the bottom hanging rail, and one through the top, per stud makes a good minimum.
We had a recent thread you should probably search for (there's a blue "Search" button on the side navigation bar in the forum). There's a nifty line of metal cabinet hangers that look like elongated "J" or "S" shapes that interlock. With those, you fasten the track on the wall securely, and the other track on the cabinet back. Slipping the two tracks together hangs the cabinet until you can get it screwed to the wall securely.
The post on blocking is something that needed to be done before the sheetrock was installed, whihc may not be valid in your case.
If you would, click on your screen name in blue--that takes you to the Member Profile area, which can help "us" help "you." (If you are a cabinet maker/installer, we don't have to tell you about screwing the faceframes or carcasses together, that sort of thing.)
Thanks for your advice. I am a homeowner and this will be the first time I have attempted to hang cabinets. I realize that the cabinets need to be level and attached to one another. I would appreciate any other advice you have that could help me with this project. Thanks!
That's usually where it gets interesting. "We" want the faces of the cabinets to be flush to one another, and to form a nice level line, plumb to the floor, or there abouts. That's easy enough to cope with. Except that the wall is never quite plumb, nor square, nor true "enough." That's when we shim, and fidget, and fudge a bit.
If we were lucky, we got to learn from someone more experienced than we were, first time out (some of use were not so lucky <g>).
Let me organize a few more thoughts, we'll see if Marty will chime in, too--we'll get you some good advice, or at least a story or two to tell . . . Occupational hazard of my occupation not being around (sorry Bubba)
I appreciate your help.
No problem, it's what "we" do here.Occupational hazard of my occupation not being around (sorry Bubba)
I'd look at SSMA load tables to see if you've got enough strength:
http://www.ssma.com/technical_library.htm
You might also try calling technical help at one of the manufacturers for their advice.
