easy question. how do you keep your nail hole putty from hardening in the can? i am tired of tossing half used putty cans. i just ditched half my collection of tinted putties. also, can they be rejuvenated in some way? what’s your fave brand/type? thanks in advance.
Tried linseed oil?
Depends on the brand and what comprises the putty. Usually a look at the ingredients will give you the answer or at the least a clue.
For instance, the ProBond brand of stuff that dries in seconds on your finger........rehydrate with methyl-ethyl-ketone. Works even if it's a dry lump in the can.
Elmer's..........water. But don't let that get completely dry and then expect to rehydrate.
when working with it, I keep a rag dipped in turpentine handy for cleaning my fingertips. Then I stick it in the can when I close it up.
Depends. Not a carpenter but I have had a few tries with various putties. Some worked well. Some less so. MEK, Lacquer thinner, acetone, mineral spirits, turpentine, water and even alcohol are options and work on some.
Check the labels. Most have some listing for a solvent to use to clean up or thin the putty. The later, at least I would think, would be the ticket. I would be careful as adding too much might cause the stuff to shrink a lot or run.
mh-patch is good stuff never had it go hard in the can either
"how do you keep your nail hole putty from hardening in the can?"
Trim,
Read the side of the can. Should list out the VOC's. Pick one and add it. See if it works.
Jon
