Hardie Plank – which filler??
We have some dings and divots in unpainted HardiePlank that need filling.
What is the recommended filler for fiber cement?
The ToolBear
“You can’t save the Earth unless you are willing to make other people sacrifice.” Dogbert
I've always just hit 'em with Quad caulk. But I'm sure there's somebody in here who'll refute that and say if you do that your house will fall down on a busload of schoolchildren...
Kinda depends on if you're using smooth or wood-grain planks due to how much you have to tool it out to blend things in.
Duke
But I'm sure there's somebody in here who'll refute that and say if you do that your house will fall down on a busload of schoolchildren...@@@Master K did the remodel framing. He does elegant framing. I have pix of his soffit detail for the kids. The second floor by way of the balconys front/back is done in 4x LVL beams for joists. It's the smooth face and will be painted or James Hardie will disown us.
Which means a bit of blend and spread smoothing.The ToolBear
"You can't save the Earth unless you are willing to make other people sacrifice." Dogbert
Probably can use anything that says it's OK on an exterior application (It will be covered by paint, yes?). Dings aren't easy to fill with caulk IMO. Kind of depends of where it is and what it needs to look like. I've been into Bondo lately, but any wood filler would probably be OK.
Dings aren't easy to fill with caulk IMO.@@@Deep ones take half day to dry. I bondo-ed the last batch on a termite job. Little nibbles. If they would get it, I would use WEST epoxy and micro balloons, as I do on the boat.The ToolBear
