hardie trimming a circular window
| Posted in Construction Techniques on September 23, 2003 12:18pm
How do you guys trim around circular (or semi-circular) windows with fiber cement?  Is there a stock solution from Hardie or another manufacturer that I haven’t seen, or do you cut and somehow laminate 4’x8′ panels to get to 3/4″ thick?  The window in question is about 36″ in diameter
thanks for any advice.
    DaveMason2 | Sep 23, 2003 04:09am | #1
     Is it possible to cut  two pieces out  of 1x8 or 1x12 Hardie trim? I've done that with cedar before.
     Just a thought, Dave
  2. CombatRescue | Sep 24, 2003 05:32am | #2
    Not really possible that I know of.  You could try lamination, but I doubt it would last or look good.  I'd consider using a different man-made product or wood.  Alternately, and expensively, replace the window with one that has trim built-in.
    1. dumfounder | Sep 24, 2003 06:00pm | #3
      The guy answering the phone for James Hardie had nothing to offer out of the box... just not worth it for them to handle such situations, I guess.
      If my calculations are right, 2 pieces of 11.5" will do a window of radius 27" or less, assuming 3.5" trim ... I'll have to double check that, but it doesn't seem like a horrible solution.  probably better than changing materials.
      Thanks to both of you... didn't see your replies until now.
  • Rainscreen for Cedar Shingles
  • Drafting the 2027 IRC
  • Get a Grip
  • Wire- and Finger-Safe Cable Stripper
