The old house I’m working on has 6 panel doors that are about 1 1/4″ thick. Some of the latches need to be replaced and I’d like to use a modern, conventional lockset.
Where can I find a lockset for skinny doors like these?
-Don
-Don
Schlage Locksets fit a 7/8" bore instead of 1". Should save you just enough room.
http://consumer.schlage.com/main/prodcat/prodcat.htm
Be Constructive
Gord
St.Margaret's Bay NS
Thanks. I'll check it out to make sure the knobs will fit the width.
-Don
I see what you mean now Don.
I've got a Schlage sitting in front of me 1¼" is about the minimum you can go. There are 2 'tails' on the interior body of the lockset I'm holding, taking those down slightly with a file would tighten the fit. Hopefully a person wouldn't have to shorten the screws too.Be Constructive
Gord
