Hardware solution?
| Posted in Construction Techniques on May 26, 2004 09:07am
When we do flat 3/4″ casings on doors, we often see the latch hitting the casing edge and dinging it, before it gets picked up by the lip of the strike plate.
We’re doing the usual 3/16″ reveal off the jamb edge.
Anyone have a hardware solution for this?  We don’t want to open the reveals.
  1. Snort | May 26, 2004 09:28pm | #1
    We've gotten long tongued Tee (shaped) strikes from our local lock shop as special order. I don't know if you can elongated Dee strikes.
    A chamfer on the casing does it sometimes.
    Just did a job with 1 1/2" thick casing, ended up with a 5/8" reveal for latch clearance, not much meat to fasten to. I thought about grinding down the latches<G>
    Don't worry, we can fix that later!
    Sphere | May 27, 2004 12:00am | #2
    sure, surface mount box locks.
A New Approach to Foundations
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
