Hardwood Floor Finishing
| Posted in General Discussion on October 4, 2004 07:14am
I apologize if this has been covered before.  I’m having newly installed red oak floors sanded and finished.  The installer is using an oil based poly. The original quote was for two coats but are two coats sufficient or is it best to go with three?  Thanks  -Ed
  1. PenobscotMan | Oct 04, 2004 07:47pm | #1
    Advice from a HO:  We had ours done (1905 house).  The guy put on two coats of non-gloss, then one coat of gloss, sanding between coats.  We were very pleased with the three coats (oil based).  Considering the mess and disruption associated with a floor sanding, I don' t think this is a place to nickel and dime.  Do it right, then enjoy.
    1. EdJW | Oct 04, 2004 09:03pm | #2
      Javier, thanks for the reply.  It's not a case of spending the extra money, the installer is telling us that 2 coats are sufficient but he'll do three if I want.  I want to do what's best but don't want to waste money either.  -Ed
  2. ed2 | Oct 05, 2004 12:58am | #3
    3 coats     look at floor w second coat dry the next am w sunlight across it     check again in same spot after 3rd coat  seals a lot of voids, makes the finished appearance
  3. IanDG | Oct 05, 2004 01:09am | #4
    The top coat is a sacrificial coat -- basically its purpose is to take the wear on the floor.
    I always used 3 coats for everything except water-base, when I used 4.
    IanDG
    1. EdJW | Oct 05, 2004 05:05pm | #5
      Thanks everyone...........3 it is.  -Ed
      1. Isamemon | Oct 07, 2004 02:11am | #6
        anyrhing less then 3 is infeior in the long run, but looks good in spec houses
        waterborne got to go 3, maybe 4
        but it all depends on the "applicator"
        Ive seen a guy put down 2 coats as thin as 1
        yeah he was fast, low bid, looked good for the check to clear
        I agree , the mess and disruption to sand and finish. Do it right , over do it
        kitchens or bathrooms, well youll end up redoing every few years anyway
  4. JeffC | Oct 07, 2004 04:10am | #7
    We went with two coats on the installer's recommendation and they made it three years.  We went with three coats this time even though the refinisher insisted two would be fine and last the average family ten years.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
