Hi folks this is berny a very green and keen carpenter. I am doing some renos at a home and there is some chips in the middle of a brazilian cherry hardwood floor. anybody has any tricks to fill or fix them. thanks
if small chips, use brazilian cherry woodfiller from woodwise or similar wood finish products co. zar and last 'n last both make same type waterbase filler in quart containers, not sure if have b.c. stuff shrinks and cracks like joint compound, fill w successive coats, sand flat, coat w same type finish as on floor will see repair, so buff 'n coat on floor not bad id if chips real big, r&r board(s)
Hi ed thank you for your help I apreciate it.
