Please advise on what size nails and nailer I should use on pre-finished 5/8 thick hardwood tongue and groove 3 1/2 wide flooring. I have the equipment for 3/4 thick. Will it work for me ?? al
use your present equipment w 2" fasteners most of the nailers, staplers come w thicker base plate for this application if not, can use thin washers on machine as shims try using the setup just as it is first, usually works just fine
