I know this situation is not ideal, but i would like to run 3/4 heart pine parallel with floor joists. Joists are 2 x 10 16 o.c. with 1 x 12 pine decking @ 45 degrees with 5/8 cdx on tap of that. Question is this still viable, mainly for aesthetics. Thanks.
There's a constant source of clean water for you to use, and all you have to do is collect it.
Quite viable.....go for it.
You`ve got two layers of subflooring and unless you were planning on nailing only at the joists, flooring direction is irrelevant.
Lemme get this straight....
YOU BANNED REZ?!?!
Holy bagels and lox Batman!
