anyone know what the going rate for hardwood installation is in the lowermainland/ fraser valley area in BC is.
The best tool for straight, splinter-free cuts is made even better without a cord.
bump
A bird does not sing because it has an answer. A bird sings because it has a song.
I think HD charges 3.50 to 4 bucks sq ft.
thnks...
If you mean 'flooring' then look at $7, finished. Min.
All the best...
To those who know - this may be obvious. To those who don't - I hope I've helped.
$7 min for installation ?
is that including floor prep?
If I remember correctly, you are located on Salt Spring, yes?
if so, how do rates where you live compare to Vancouver.
I'm in the Fraser Valley.
If the dynamic is anything like over here, then prices on Salt Spring will be higher than in Vancouver. Here there are fewer tradesmen on the island than the mainland and prices for everything are higher due to that and also ferry costs.
Sure, that was the rate on SSI - I've lost track now I'm on the big island . But that was from the guy walking in to the sanded and finished product.All the best...
How much costs is attributed to finishing?
if it's engineered is cost about half?
Hey all y'all lower rainlanders... fill in your profile so's we can see where we're all at...I'm in Burnaby, Aaron's in Vangroovy....etc...cheers,Phil."If 'tis to be,'twil be done by me."
dunno - but then again, you'd be better off getting quotes closer to home.All the best...
