headers, window rough openings
jinalaska | Posted in Construction Techniques on August 1, 2006 05:40am
in a load bearing wall i have an opening roughly 7 feet , i have room for 9″ worth of header above this opening,  is this sufficient…also rule of thumb for window rough openings? 1″larger than window enough?..thanks for the info yesterday
    dieselpig | Aug 01, 2006 11:33pm | #1
    Nobody can answer that question for you with knowing what the header is supporting dude.
    Regarding your RO question.... all the manufacturers are different.  Look up your window unit in either the manufacturer's book or website and it will tell you what RO to frame to.  If the window is onsite already, just measure it and add 3/4" all the way around unless you frame really crooked and then you'll need to add more.  :)
A New Approach to Foundations
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
