Is there any way to tell a heat pump from a regular unit by looking at the condenser?
Maybe something in the serial number or some other way.
There's a constant source of clean water for you to use, and all you have to do is collect it.
What's a 'regular unit'?
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
bambam definition: Any unit other than a heat pump.
The extent of my HVAC knowledge is to call my local sub and have him do it. I had a customer want to know and I was just wondering thats all.
Heat pump will have a reversing valve, ya gotta be able to look inside to see it sometimes, but often can see it thru the grill on the top.
It's a about 1-3/4 dia tube 8 " long with a couple of wires to it and a bunch of 3/4 inch tubes coming out the side of the big tube.
You can also tell by the part number, everybody is different.
Just look the P/N up on the web unless it's and old unit, then sol.
PS: If you want to get razzed, go post in hvac-talk.com -- oh yeah, be sure to tell them you want to know 'cause you want to convert your AC to heat pump DIY. <G>
Edited 11/29/2006 2:16 pm ET by junkhound
