I am planning for DIY tile floors in three baths and would like to install electric heat mats under the tile.
The subfloor is 7/8″ Georgia Pacific sturdi-floor over 2 x 4 floor trusses 16″ OC.
1. Do I need to install a layer of backerboard on top of the plywood subfloor?
2. From your experience, have you been pleased with the performance of the uncoupling layer (Ditra-Mat)? Should this be used instead of additional backerboard, or should I install backerboard then heat mats then Ditra-Mat?
The flooring in the rooms adjacent to these baths will be 3/4″ hardwood.
Thanks to all,
realtreegrower
Greetings real,
As a first time poster Welcome to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Click here for access to the Woodshed Tavern
Click here to visit the beginning of Breaktime
