Help with corner trim….PLEASE!!!
ShortBil | Posted in Construction Techniques on November 20, 2008 02:21am
How do i cut inside corners on corner trim to fit up to ceiling and wall?? Is it cut like crown?
Anyone know what I mean???
Thanks!
    ToolFreakBlue | Nov 20, 2008 02:51am | #1
    I do not know what you mean.
    What is the profile? Scotia/Cove, Qtr round, Flat stock or a small crown?
    Specifically are trimming the wall ceiling intersection or a wall to wall intersection?
    TFB (Bill)
    PeterJ | Nov 20, 2008 03:07am | #2
    I'm thinking cove molding running  around perimeter of room @ ceiling, and you're wanting to intersect cove molding running vertical in corners with that.
    Am I close?
  3. Jed42 | Nov 20, 2008 03:12am | #3
    if it's cove...Hold it on the fence of your saw like it sits on the wall...in other words, pretend the fence is the wall and the table is the ceiling . And yes...it is sorta like cutting crown...you can think of it that way, backward upsidedown cuts...this stuff makes me think every once in a while...and if you get in a hurry it'll getcha!
    Good luck to you
    No Coffee No Workee!
    Sphere | Nov 20, 2008 03:15am | #4
    If you are thinking a three way miter, stop thinking that way. I won't work effortlessly, and the effort outweighs the advantage.
    That detail always looks like crud, but when you are using the same stock ( as in a panelled room) thats what you get. You need to vary either the corner detail or the crown detail.
    1. ShortBil | Nov 20, 2008 03:21am | #5
      It is cove, it's just to trim the top of new pantry.
      It is for wall to ceiling.
      Thanks everyone!
      Edited 11/19/2008 7:24 pm ET by ShortBil
        Sphere | Nov 20, 2008 03:26am | #6
        Hold it in the miter box as it will be seen.  Like it will be on the pantry, no need to cut it upside down and backwards like crown.Spheramid Enterprises Architectural Woodworks
        1. JMadson | Nov 20, 2008 05:11am | #7
          He could also cope the corner (like an inside crown corner) it would look the best if done right.
            Sphere | Nov 20, 2008 03:16pm | #8
            If I got it right, I'm picturing 3/4" COVE molding, it don't get coped. No need to. It doesn't shrink up and open gaps, and is a real PITA to cope.
            You ever cope that profile?
            But I could be mis-picturing what he is talking about, that happens. I STILL cant figure what MSLietys shed roof is supposed to be..I got lost somewhere when Framer started with the trapeziods.Spheramid Enterprises Architectural Woodworks
    2. JoeBartok | Nov 22, 2008 05:48pm | #9
      "If you are thinking a three way miter, stop thinking that way. I won't work effortlessly, and the effort outweighs the advantage."
      It's possible to cut a three way miter under certain conditions. The profile must be symmetrical about the centerline of the material, and all the angles at the intersection must be equal.Study of a Three Branch Compound JointJoe Bartok
        Sphere | Nov 22, 2008 05:53pm | #10
        Man, I love your stuff, you never cease to amaze me.Spheramid Enterprises Architectural Woodworks
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • What You Need to Know About Installing Steel Siding
  • Podcast 570: PRO TALK With Project Manager Jeremy Hess, Part 1
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
