Hinge Pins with C Rings
| Posted in General Discussion on February 4, 2003 11:57am
I was working on a door in my 1935 house and noticed that each hinge pin has a C rings about 1/4 inch down from the top.  The ring is relatively wide compared to it’s diameter, like the rings which go around a piston in an engine.  I assume this helps keep the pins from working out.
I’ve never noticed this before and I’ve removed a fair number of hinge pins.  Everything else about the hinges on this door is perfectly ordinary.  The hinges are stamped Stanley.
My questions are:
1)  Is this unusual or have I just failed to observe it before?
2)  If I wanted to buy a similar hinge pin, how would I specify it?
A New Approach to Foundations
