Please advise on favorite technique.
Please: something more clever than “plug in, pull trigger, apply spinning blade to wood!”
I’ve seen some users lean 2×4 against right leg, holding saw in RH and stud in LH, with saw more vertical than horizontal, to allow for gravity-assisted cuts.
Thanks!
KAS - you got the jist of it. Gravity is your friend. Whenever possible, tip or position the lumber so that the saw "falls" through it as it cuts. - jb
Please: something more clever than "plug in, pull trigger, apply spinning blade to wood!"
I've seen some users lean 2x4 against right leg, holding saw in RH and stud in LH, with saw more vertical than horizontal, to allow for gravity-assisted cuts.
Thanks!
