How do I calculate ridge beam size?
| Posted in General Discussion on October 31, 2000 01:01am
I am putting on an 18′ deepby 34′ wide addition with a 6/12 pitch.
using 2×10’s 16″ on center.
Should I use a plywood type laminated beam, or the 2×4 type laminated beam?
The distance from the ridge to top of wall is approx. 20′
Thanks Morgan
  1. Tommy_B. | Oct 29, 2000 01:55pm | #1
    Much of the information needed to answer your question is missing, leading me to believe that you are in over your head. Is the ridge structural? Is the ceiling vaulted? Will there be collar ties?
    Given the appropriate specifications this would be an easy calculation that your beam supplier could probably handle. I would have it reviewed by my structural engineer and have him sign off on it anyway for two reasons, liablity and the building inspector would probably require it.
    You would be foolish to accept the advice of anonymous web surfers in this regard.
    Tom
    1. Boss_Hog | Oct 29, 2000 11:55pm | #2
      *Tommy B is right on. We would also need info about local building codes and live load requirements. Go to a lumberyard or truss manufacturer - They should be able to steer you in the right direction.
      1. Joe_Fusco_ | Oct 30, 2000 12:04am | #3
        *Morgan Fazzary,
        Unless this ridge is fully supported down to the foundation, the answer is. . . None. The ridge is just to provide a nailing surface for the rafters (which could be nailed to each other) and is structurally not necessary.But somehow I'm sure that's not the answer you were looking for. . .
        View Image © 1999-2000"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich W. Nietzsche
        1. Qtrmeg_ | Oct 31, 2000 12:00am | #4
          *Joe, are you trying to start something? >>> "None. The ridge is just to provide a nailing surface for the rafters" Anyhow Morgan, is the ceiling vaulted?
          1. The_Tennis_Court_Builder_...on_t | Oct 31, 2000 12:14am | #5
            *Joe meant to add that if there are ceiling joists then the ridge is non-structural....The others are assuming that this is a vaulted area since you are toying with loads...All the beam manufacturers will take a fax of your situation and fax back to you your solution for free.near the stream and BOZO Joe, LOL LOL LOL LOL LOL LOL aj
          2. Joe_Fusco_ | Oct 31, 2000 12:51am | #6
            * Qtrmeg,
            If I wanted to start something you'd have no need to ask.
            "Unless this ridge is fully supported down to the foundation, the answer is. . . None. The ridge is just to provide a nailing surface for the rafters (which could be nailed to each other) and is structurally not necessary.But somehow I'm sure that's not the answer you were looking for. . . "
            I think that's clear don't you?
            View Image © 1999-2000 "He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich W. Nietzsche
          3. The_Tennis_Court_Builder_...on_t | Oct 31, 2000 01:01am | #7
            *Only clear in your peanut brain Fuksco...near the stream baiting the hook...using the jerk, catch and release method...LOL LOL LOL LOL LOL LOL LOL LOLaj
  2. morgan_fazzary | Oct 31, 2000 01:01am | #8
    I am putting on an 18' deepby 34' wide addition with a 6/12 pitch.
    using 2x10's 16" on center.
    Should I use a plywood type laminated beam, or the 2x4 type laminated beam?
    The distance from the ridge to top of wall is approx. 20'
    Thanks Morgan
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
