Does anyone happen to know the height at which a wall sconce should be? In a hallway with 9′ ceilings? In a bathroom flanking a bathtub with 8′ ceilings? And in a bedroom with 8′ ceilings. The sconces will be the open bulb type with upward illumination. My wife keeps telling me 5′, I keep saying that anyone taller than 5′ will see the bulb and also smack into it. thanks.
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
This isn't gonna be a definitive answer, but... where it looks good. I mounted mine with the top of the glass shade at my eye level (‘bout 5’-9”). Now, where mine are located no one can run into ‘em.
I’m also not married, but if I were, I’d let this one go…
Liberal Arts Graduate
Will Think for Food
We used 6' after discussing this with our electrician and everyone in earshot. Happy with the choice.
I have lots of sconces and love them. I'd say you have it about right, you want them a little above eye level, but within easy reach for changing bulbs. If you're absolutely sure that there'll always be a piece of furniture against the wall under the sconces, you might put them lower, say for over a bed as reading lights, or over a small table in a telephone nook.
-- J.S.
At 6'2", if there were at 5', I'd never turn them on...assuming I'd see the bulb, just like you are describing.
I put my about 7'8" on my 10' ceilings...I like how they look.
My thoughts for them are background lighting...not reading. But like John said, if they are over a known reading position...
I think 5' too low.
Agree with other re: eye-level and bulbs.
6'-ish is more typical. Ours range from 6' to 6'5", they look fine to both me (6'4") and my wife (5'1").
I usually put them at 6' unless there's a good reason not to. For example, when you need a light over a vanity in a narrow space, you may have to go above the mirror.
There is an electical code issue with sconces near tubs; the fixture can't be reachable from the tub. I forget the specifics.
For safety, the bulb should always be at least 18" down from the ceiling.
They are more for ambience lighting than for area lighting, as a generall rule.
I aim for about 70" to 74" from floor to center of the mounting box. This is based on the advice of a lighting expert that was hired to direct my ways and enlighten my thoughts on a job once. I've been doing it since and never heard a complaint
Ok I got to add my two cents worth because the timing is right.(I'm building a new house)I had the same question on monday and heres what I learned. I called several lighting companies and manufactures,some on line ,some in the yellow pages.1st call 72",2nd call (a manufacture) no friggin clue, 3rd call 5'6",4th call 62-64",5th call 5'6",and 6th call 5'7"or at eye level. I then took some cardboard and cut it the rough size of the wall sconce just to see what it would look like on the wall With that info I went with the 5'6" mark I also used the cardboard trick(made a 52"cardboard circle) when I was installing a lot of recessed cans and two ceiling fans It was a pain measuring around where the fan blades would come in contact with the light trying to avoid a strobe light affect it.The cardboard might look a little silly but it worked for me. good luck Greg
wherever she wants it...
...end of the story, discussion, argument. That's the best and logical answer.
Tom
Just be sure you document what she says the first time. ;<)
Thanks to all,
I suppose I can let my wife read these, then just do it the way she wants. It's nice to know when you're on the right track even if you can't say it out loud.
Oh, now you've changed to track lighting, what are you, a woman?
Wonder how high you mount the track... arrrrrrrr, just let her decide.
