How to build door/window crown trim?
forest | Posted in General Discussion on March 23, 2006 07:18am
I want to build that craftsman style (1910?) door/window trim. It is a simple flat 4.5″ wide trim butted around the opening, the head casing has a small bullnose between the side casings and the head casing. But ontop of that is a good size crown, about 2 1/4″ high on the houses I have looked at. How do you build this crown? I am attaching a picture of this style of trim. The part I am asking about specifically is the crown on top. I can’t buy anything off the shelf like this here in our town. Can this be built up? I looked in the Lee Valley catalogue, but they don’t make a single bit this big. Does anyone have suggestions for building this head crown trim?
  1. Ragnar17 | Mar 23, 2006 07:35am | #1
    Forest,
    The part you're asking about is called a door or window cap.  The stuff I usually use is milled from nominal 2x3 and dresses down to 1-3/8" tall by 2-3/8" projection.  There is a 1/4" x 3/4" rabbet so that the cap sits on the 1x6 head casing.
    I'm not sure if you can find any knives to mill such a piece -- I just always get mine from the local lumber yards.  Could you get someone to produce a custom run for you?  I could probably send you a scan of the cross-section if you were interested.
    Alternatively, you could build a similar look using a crown and a dust cap.
    hammer1 | Mar 23, 2006 07:37am | #2
    I just posted of picture of this one I recently made, can't find the post though. I used some pine to cut down on the amount of mahogany needed. Folks make these type of headcasings up from all kinds of shapes. It's a lot of work if you are doing a whole house. One of my hardwood suppliers stocks headcasing in oak and poplar, they will run any species on a special order. Many shops have molders that may also be a source for single piece moldings. Whether you assemble your own or have it made, you have to miter the returns on each end. The window picture is one piece.
  • Fine Homebuilding's Author Guidelines
