How to prevent voids in concrete
| Posted in General Discussion on July 18, 2001 11:12am
Have a re occurring problem that I am hoping you might be able to help us
with.
We are residential builders in Northern California.
Our problem is having problems with voids and pockets in our upright pours,
columns and walls. Some of the pockets go through the complete wall.
Our mix is usually a 3/8″ grout mix for pumping, with usual requirement of
2500 to 4000 psi. with a 4 to 5″ slump. We are careful about using a
vibrator around all edges as we pour. The batch plant is at least 1 Jr away
from our building sites.
Is there anyway to prevent the pockets?
What is the correct procedure for repairing those that occur?
  1. FrankF_ | Jul 18, 2001 11:12pm | #1
    with.
    Our mix is usually a 3/8" grout mix for pumping, with usual requirement of
    2500 to 4000 psi. with a 4 to 5" slump. We are careful about using a
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
