I poured my slab with a few PFB1 boxes for installing duplex outlets. I will be installing tile. Which is the best cover for this? The catalogue says the S5016 must be used but the dimensions do not seem right. ????
The best tool for straight, splinter-free cuts is made even better without a cord.
kazm
you have to do some work.
Copy paste a link to what you have and what you need.
I looked at Hubble, found your box-round.
There's a list of covers that seem in the same section as I found the box-however, there's no number like you posted.
there's these however. They do show pictures, but couldn't copy the pdf file.
but, picking through the pdf page 8, I find the pfb1 box and the S5016 cover.............but I also see on that page you might need the adapter ring for the BOX-it appears that the tile ring might fit up to that adapter ring. It's also plastic.
The link below might work-go to page 8.
http://www.hubbell-wiring.com/press/catalog/L.pdf
If this doesn't help-go to your supplier and ask.
God help you if you're hoping for the best and ordering off the internet. If you are-please call that IT supplier and talk to a human being.
