In the course of my tenure as a nail-bending thumb-banger ,(no waffle heads for me thank you ) I like to think I have picked up some decent knowlege-experience and practices that justify me calling myself a carpenter , finish carpenter, custom builder as the situation permits. So I have bought my 1st house w/ the intent of puting my stamp on it ,which I am. Unassuming 24′ x32′ ranch circa 1960,needs atention. N.W. Me. Near White Mtns.. So I’m ripping off neglected pine clapboards cupped &split so bad,replacing w/ white cedar shingles S & R. ,dipped for 1/2hour in penofin (a marine-based penatrating oil ). Will build-up corners w/ mahogany(cambara) 2x stock. Have already started w/ milled up 2×6 mahogany water table to start a flair (that &3 courses make up the flair) . 4′ to the weather ’cause I want to,5d s.s.ring shank ,1×8 T&G sheathing, and (here we go ) typar housewrap. I intend in the future to install a vapor barrier throughout the interior (possibly in the form of icynene blown insulation [which is in itself a vapor-air barrier] ) and 5/8″sheetrock to replace the 3/8″ I now have. Even though I’m a “newby” to this forum ,I’ve been busy. Iknow there are currently 2 discussions on this topic hotly contested ,as well as a $hi+load in the archives. My question is “Do I have to tear off what I started to install 4″o.c. furring strips , or tar paper or cedar breather ? I’m quite confident I can keep out the elements and /or channel out any pesky intrusions ( I’ve even used one of Mike Guertin’s tips & installed a clapboard on the framed sill of a window I replaced . thanks Mike ! ) My point is I don’t think my house will fall down But w/ what I’ve been reading, if anyone can convince me otherwise I’ll consider tearing stuff apart (grumble-grumble) Thank you all !!
From plumbing failures to environmental near disasters, OHJ staffers dish on our worst and best moments.
I'm not really shure what aspect of your work your question is in regards to, but I think its the Typar under the Cedar shingles, no?
If Typar has a history of reacting with your cedar, then I'd worry about that.
If Typar + cedar's OK, then I guess that only leaves the question of a rain screen or breather. It seems to me that shingles will breathe more easily than clapboards would, so maybe you'd be OK without? (as long as you've already done it!)
*Norm - From what I've read, It's Tyvek that breaks down behind bare cedar ,(that base is covered) Thanks for your input though . Wes
*Wes,I think you will find that your worries are unfounded if you visit http://www.cedarbureau.orgTom
*Thanks, Tommy B...........................That's a large site isn't it ?
In the course of my tenure as a nail-bending thumb-banger ,(no waffle heads for me thank you ) I like to think I have picked up some decent knowlege-experience and practices that justify me calling myself a carpenter , finish carpenter, custom builder as the situation permits. So I have bought my 1st house w/ the intent of puting my stamp on it ,which I am. Unassuming 24' x32' ranch circa 1960,needs atention. N.W. Me. Near White Mtns.. So I'm ripping off neglected pine clapboards cupped &split so bad,replacing w/ white cedar shingles S & R. ,dipped for 1/2hour in penofin (a marine-based penatrating oil ). Will build-up corners w/ mahogany(cambara) 2x stock. Have already started w/ milled up 2x6 mahogany water table to start a flair (that &3 courses make up the flair) . 4' to the weather 'cause I want to,5d s.s.ring shank ,1x8 T&G sheathing, and (here we go ) typar housewrap. I intend in the future to install a vapor barrier throughout the interior (possibly in the form of icynene blown insulation [which is in itself a vapor-air barrier] ) and 5/8"sheetrock to replace the 3/8" I now have. Even though I'm a "newby" to this forum ,I've been busy. Iknow there are currently 2 discussions on this topic hotly contested ,as well as a $hi+load in the archives. My question is "Do I have to tear off what I started to install 4"o.c. furring strips , or tar paper or cedar breather ? I'm quite confident I can keep out the elements and /or channel out any pesky intrusions ( I've even used one of Mike Guertin's tips & installed a clapboard on the framed sill of a window I replaced . thanks Mike ! ) My point is I don't think my house will fall down But w/ what I've been reading, if anyone can convince me otherwise I'll consider tearing stuff apart (grumble-grumble) Thank you all !!
