I lost the fly ash question
brownbagg | Posted in General Discussion on March 3, 2007 03:25am
He is 100% right but…………
fly ash is a by product of coal fired furances. Fly ash as the same chemical properties has cement when it reacts with calicum hydroxide which is a by product of curing concrete.
fly ash can replace up to 45% of cement by weight. and fly ash is free.
the properties of a fly ash mix is. because less cement is used, the mix is not as hot, it will setup slower. Because the particles are more rounder it make a more worable mix with a lower water cement ratio.
the fly ash does not start to react till the calicum reacts which is usually around 10-14 days. so the mix starts off slow and doesnt gain maximum strength till last of 28 days. what this does is reducing cracking due to shrinkage.
in conclusion.
mix is cheaper
mix is more workable
mix controls cracking
mix is just as good as the high dollar mix but……………
if you need to set steel fast, you you a staight cement mix with super P.
Give me a three inch mix 6 sack straight with super P and I can gurantee you 3500 in 3 days. Pour on friday, hang steel on monday
    SamT | Mar 03, 2007 09:16am | #1
    Thank you sir,
    I just saved this page to my "Resources" folder.
    SamT
    Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either. [Einstein] Tks, BossHogg.
Podcast Episode 695: Saving Bricks, Cut-and-Cobble Insulation, and Waterproofing Foundations
Listeners write in about paint strippers, bricks, and FHB Podcast volume and ask questions about insulating under membrane roofs and whether waterproofing prevents concrete foundations from drying.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
