I am a potential owner builder on a small budget with a piece of property that has a rocky ridge on the north side and a south facing slope. Mindful of increasing energy prices and tired of paying through the nose to heat my home, I would like to take this opportunity to do it right the first time. I have never built before but have become quite knowledgeable of what is out there and love the whole concept of “Not so Big”.
After much deliberation, I’m considering either ICF all the way….I see it being done with my friend’s house and it is exceptional, or Timber Frame with SIPS. The nice thing about the latter is that it goes up quickly and eliminates alot of stages but the thing about ICF is the passive solar element with the thermal mass in the walls. Any thoughts out there on either of those?
I really want to have a solar water heater and a masonry stove heater too. Would the SIPS be enough to have a passive solar home? I would probably (if I went with the Timberframe kit I’m looking at) go with a 24w x36 length saltbox with a 10ft shed on the width side. The house would face south on its long axis with the shed on the north side. By the way, when I say Timber Frame do not imagine huge cathedral ceilings with a massive open to below….that is not what I want and there are many cozy ‘not so big’ houses using the timberframes.
That’s the overview…….any thoughts from voices of experience?
I am a Residential Designer in Michigan. I have designed several ICF homes with SIP roofs there is no doubt the ICF way would give you the best bang for the buck. I currently have 3 Hybrid ICF homes going up. I have also designed several Sip homes. But from my clients and builders perspective ICF's with a SIP panel roof is the best way.
Sincerely,
Eric
Image Design, LLC
[email protected]
You said you were on a small budget.
Masonry heaters (like timberframe & SIP construction) are very pricey, aren't they?
Unless you are in a very fridgid climate I would think this is overkill inside a SIP house.
An airtight woodstove (properly sized for your house) ought to keep you plenty warm.
It also should heat up the space more rapidly than the masonry heater.
A masonry heater has the advantage of retaining heat longer but a SIP house already gives you that, right?
