inside radius in tile
Spm37 | Posted in General Discussion on September 18, 2009 03:21am
looking for ideas to cut smooth inside rdius in tile  this edge will become a grout joint so it has to be nice ! know about the cut and nip technique trying not to go buy expensive specialty equip only have two tiles to cut- have a qualityhwet saw and small 4 in grinder with diamond blade  Thanks Steve
  1. danusan10 | Sep 18, 2009 03:34am | #1
    Well you got everything you need, just need to get the bulk out use either saw clean up with the angle grinder to the radius line.
  2. joeh | Sep 18, 2009 04:08am | #2
    You have it all, give it a try opn scrap and you'll figure it out.
    If the radius is bigger than the diameter of your 4" grinder you can use it on the flat instead of from the side, makes a smooth curve easily.
    Joe H
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
