Install a prefab fireplace in chase?
This job is like chicken and egg.
For cold climate install….
1)Insulate chase top and bottom
2) Finish with drywall
3) install cold air kit
4) set fireplace
5) How do you install the chimney once the fireplace is in? There is no access to bottom of chase?
Do you set the fireplace….install chimney thru roof and then just make final connection on top of fireplace reaching from inside after chimney is in?
Thoughts? Thanks
Greetings b,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Andrew Clifford of Clifford Renovations, who serves as a steward of our history for future generations
We can imagine something that only exists in our heads, in a form that has no measurable, tangible reality, and make it actually occur in the real world. Where there was nothing, now there is something.
Forrest - makin' magic every day
Awful short on details.....are you talking about a gas unit? Is it exhausting through a chimney or a chase? Both?
Typically, as with any mechanical, all parts that need to be roughed ....connections made....are done so prior to closing of walls/floors.
J. D. Reynolds
Home Improvements
No this is a wood unit and a chase needs to be framed. How high needs to be insulated?
I converted from gas to wood burning. We "grew" the dog house (that housed the gas fireplace) all the way up the back wall of the house and extended the roof to cover it. We pulled the gas FP, installed the woodburning unit. Pulled roof off dog house, removed siding up to roof and framed chase. The chimney pipe came in 4ft sections so we insulated and drywalled (all the way to the top) as we went up.
I have pictures if you would like to see them.
Edited 10/12/2006 1:57 pm ET by Womble
Could you email me some photos or post them? Thanks
