Install wainscot without blocking
housenut1 | Posted in General Discussion on August 8, 2006 02:38am
What type of adhesive should I use to install seventy year old 3/4 x 42 inch varied widths (up to nine inches) pine boards in a small mud room? The area without the blocking is a short corner run of three feet on each wall.  I figure I can nail into the bottom plate but I didn’t install blocking at the top.  I hope I don’t have to cut out the drywall to do it right.
Thanks in advance
    IMERC | Aug 08, 2006 03:25pm | #1
    PL premium.
    WOW!!! What a Ride!
    1. housenut1 | Aug 12, 2006 11:00pm | #2
      Thanks IMERC I go out and buy some.
        IMERC | Aug 12, 2006 11:10pm | #3
        and zipper pin it to the DW till the PL sets up...
        1. housenut1 | Aug 17, 2006 03:04pm | #5
          Thanks again for the tip IMERC.  As a carpenter wanna be I have to admit I don't know what the method of "zipper pin" is.  Could you tell me what it is and how to do it?
            IMERC | Aug 17, 2006 06:07pm | #8
            counter angle the pins into the drywall for mechanical holding power..
  2. DonCanDo | Aug 12, 2006 11:45pm | #4
    I've got a similar job coming up.  I'm planning on using Loctite Power Grab.  I really like how it doesn't skin over quickly like the PL products, it cleans up with water and it's got a realy high initial tack.
    It's probably not as strong as PL premium, but I figure I don't really need strength to hold paneling to the wall.  Oh, did I mention I'm installing beadboard paneling?  Well it should still work on your T&G, but the PL premium is might be a better bet and skinning over won't be as big a concern since your pieces are much smaller.
    -Don
    1. housenut1 | Aug 17, 2006 03:05pm | #6
       DonCanDo:
      Thanks for the optional tip.  I'll keep this type in mind for the future.
    DDay | Aug 17, 2006 04:14pm | #7
    If you shoot the nails at an angle, it will definitely hold well enough, and certainly enough for the glue to set up.  What he probably means by zipper is nailing at an angle to the right and left at the same spot.  This keep it from moving anywhere.
Podcast Episode 695: Saving Bricks, Cut-and-Cobble Insulation, and Waterproofing Foundations
Listeners write in about paint strippers, bricks, and FHB Podcast volume and ask questions about insulating under membrane roofs and whether waterproofing prevents concrete foundations from drying.
  • The New Old Colonial
