Installing grab bars on new tile wall.
| Posted in General Discussion on August 23, 2002 05:10am
The new tile is over doubled concrete board and the studs are not regular behind it. Do I need more than the usual plastic sheaths and how long should the screws be? I have a special bit to drill the holes.
Another short grab bar in front of the toilet will go into plaster. Before doing over the bathroom that bar had come loose. What should I do to make sure it holds?
Joyous24
  1. jet | Aug 23, 2002 05:12am | #1
    MOLLY SCREWS.  Plastic inserts will not hold enough.
    1. Joyous24 | Aug 23, 2002 05:26am | #2
      thank you
      Joyous
  2. exlrrp | Aug 23, 2002 03:56pm | #3
    Molly bolts
    Get the biggest ones you can use for the grab bar and drill the smallest possibl;e hole so it grabs the best--the grab bar should havd been planned for and blocked. Try and get at least one end firmly screwed to a stud
    The inserts might work for the towel bar but a molly holds better there too
    1. Joyous24 | Aug 23, 2002 04:22pm | #4
      thanks!
      Will visit my home away f r om home today and get molly bolts.
        BarryE | Aug 23, 2002 09:24pm | #5
        http://www.wingits.com/
        It's not the habitat, it's the inhabitants.
        Won't you be my neighbor
Outdoor Lighting
