In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Installing Granite Countertops
HansonConstruction | Posted in Construction Techniques on February 18, 2008 05:21am
I have a potential job next week installing a granite countertop for a customer who didn’t want to wait the three months it would take (so she says) to schedule the granite guy’s crew.
It will already be cut-to-fit, of course, so it looks like all I’ll have to do it remove the old countertop and then place and fit the new one. I expect I’ll have to shim, etc. to get the pieces to match up.
I found one article on FineHomebuilding.com, and it said that the countertop is basically glued to the cabinet frame with clear silicone caulk, and that the pieces are also joined together using clear silicone caulk (as the silicone allows for expansion and contraction. That all seems pretty straightforward.
Does anyone have any experience, tips, do’s or don’ts for me?
Thanks.
– Eric Hanson
    BarryE | Feb 18, 2008 05:27pm | #1
    Somebody recently asked the very same question:
    http://forums.taunton.com/tp-breaktime/messages?msg=101037.1
    Barry E-Remodeler
  2. VTNorm | Feb 18, 2008 05:29pm | #2
    I watched the stone guys install a piece last week on a book case I did for a client and it was just that; set the stone, shim to level and random beads of silicone. They did wash down the to-be-glued side of the stone to get rid of the dust before installing.
    No seams, can't help with that question.
    -Norm
  3. jeffwoodwork | Feb 19, 2008 01:11am | #3
    The seams usually are not siliconed, and an epoxy that matches the stone is used to seam.
    NickNukeEm | Feb 19, 2008 03:48am | #4
    Seams are joined using a two part epoxy system that usually gives me a wicked headache.
    A dual suction cup clamp fastens to each piece of stone and  a ratching lever is used to force the two pieces together.  The better clamps have vertical adjustment knobs to tweak the stone.  Use a razor blade (one side) to check for coplaner between the two pieces.  (Use the razor on edge, slipping it perpendicularly over the seam.  The razor will catch on the smallest difference in height between the stones.  It really works.  The blade is also used to clean off the epoxy.)
    Depending on the crews and stones, I've seen some who use silicone to fasten the stone to cabinets, but I've also seen some who just let gravity to its job.
    Make sure you shim as required so all the stone is supported, where possible.   I went to a bathroom vanity DIY job once to prep the vanity after the stone company had refused to install due to the out of level and poor coplaner conditions.
    "I am the master of my fate, I am the captain of my soul."  Invictus, by Henley.
    1. HansonConstruction | Feb 19, 2008 03:55am | #5
      Thanks. That's good info. I don't have the suction cup set-up available, but I think that I can work out a clamping solution.
        EricPaulson | Feb 19, 2008 04:07am | #6
        In the edges to be joined...........you may wish to grind in some keys..........think like slots for bicuits here (only about 1/8 or so deep though) to help hold things together.[email protected]
        1. HansonConstruction | Feb 19, 2008 04:16am | #7
          Thanks. It's the joints that are giving me pause. Any advice is greatly appreciated.
            EricPaulson | Feb 19, 2008 04:23am | #8
            Make sure you dry fit them first and do any shimming you need to do before you consider glueing them up.
            Did you source the epoxy and the tint(s)?
            Try a rental place for the suction cup things. I've seen it done with blocks of wood hot melt glued to the top then clamped with limited success.[email protected]
          2. HansonConstruction | Feb 19, 2008 06:00am | #9
            I haven't sourced the epoxy or tints. Do you have any suggestions?
            EricPaulson | Feb 19, 2008 01:52pm | #11
            Start googling![email protected]
    JeffBuck | Feb 19, 2008 08:12am | #10
    my first thot would be to call local granite places to see who much and how fast I could sub it out for.
    3 months to set a CT that's already cut and fit?
    something ain't right there.
    who templated, cut, dropped off and fit it w/o sticking it down?
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
How to Install Exterior Laminate PVC Siding
In this video, learn how hidden fasteners make for a seamless feature wall.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
