installing hardwood over radiant heat
I have a question about installing hardwood floor over radiant under-floor heat. The homeowner wants the flooring installed parallel to the joists, which would mean much of the nailing should occur between joists and right above (and potentially through) the water/heat pipes. How is this issue addressed?
Thanks!
Sue
How is the radiant heat ran?
"There are about 550000000 firearms in worldwide circulation. That's one firearm for every twelve people on the planet. The only question is...........How do we arm the other eleven?" Yuri Orlov
Well.... it was installed before I got there, and the only way I can examine it is by going into a crawlspace, but it appears to be in loops fastened right under the subfloor with some kind of clips. I'm pretty sure I'm in trouble if I nail anywhere between the joists, at least with nails long enough to penetrate the subfloor.Sue
Yeah nailing the pipe would suck.
I helped a friend do his floor.
we dropped the under pinned radiant heat --- put floor in --- then re-fastened the pipe to the sub-floor."There are about 550000000 firearms in worldwide circulation. That's one firearm for every twelve people on the planet. The only question is...........How do we arm the other eleven?" Yuri Orlov<!----><!----><!---->
I'd have to do that lying on my back in the crawlspace. I don't think so. Sue
Use nails that won't penetrate.-------------------------------------
-=Northeast Radiant Technology=-
Radiant Design, Consultation, Parts Supply
http://www.NRTradiant.com
How thick is the subfloor? I would try to talk the homeowner into installing it perpendicular to the joists.
I had the same issue in my house when I installed hardwood, but didn't install parallel. I left the radiant tubing down about 3/4" below sublfoor for that reason.
