Installing patio door
mencheman | Posted in Construction Techniques on August 12, 2009 09:05am
installing a new patio door – the question
Should I install a sill or threshold pan ?
I used tar paper to set the door on .
should I install a cleat under the front of the threshold so it doesnt flex
    Huck | Aug 12, 2009 09:14pm | #1
    its on a slab, a raised foundation, a second-story patio,...??
    View Image bakersfieldremodel.com
  2. rnsykes | Aug 13, 2009 12:08am | #2
    In most all cases.... Yes and Yes. I just replaced a patio door on the second floor of a house 3 blocks from the beach. It was the original Therma-tru 6068 door that was installed when the house was built 8 years ago. It was leaking so bad that the mdf casing on the inside was growing mushrooms. I'm not even joking. Both jambs and the center post were completely rotted. The sad part is that they had both been painted every other summer and still failed. 8 YEARS!!!!! Therma-tru told me to go kick rocks since it's a coastal application, so I got an Anderson Frencwood gliding door to replace it. When I removed the 1 nail holding the door in, and got the Door out, I was pleasantly surprised that the aluminum sill pan had protected 99% of the framing. Just a little bit of damage to the bottoms of the jack studs. I wasn't expecting a sill pan since the deck that the door opens to is fiberglass. I would have assumed that the glassing went right up and under the door. As for the stiffener for the sill. Why wouldn't you put it in? The sills aren't made to bed down at the front edge. Infact, I think you'll probably be able to get a metal stiffener that fits into the bottom of the sill.
  3. Piffin | Aug 13, 2009 12:16am | #3
    yes on the pan. It protects woof faming from rotting
    The 'cleat' is called an apron and is a standard part of the exterior trim detailing
    1. rnsykes | Aug 13, 2009 12:17am | #4
      Yeah, it terrible when you woof framing gets wet. Always smells like wet dog. The hounds are especially offended by that.
      Edited 8/12/2009 5:18 pm ET by rnsykes
        Huck | Aug 13, 2009 01:33am | #5
        The woof tends to warp when it get wet - and I'm not fabricating that!View Image bakersfieldremodel.com
    2. mencheman | Aug 13, 2009 02:37pm | #6
      apron , yes thank you
      1. Piffin | Aug 13, 2009 02:40pm | #7
        The last door apron we did - we used azek instead of woof;)
        1. mencheman | Aug 13, 2009 04:25pm | #8
          we want this pan to wrap down in the front and turn up on inside and sides. So the inside of this sits with a 1/2' or 1" up turn that my be visable inside Yes
          1. Piffin | Aug 13, 2009 04:32pm | #9
            runa shoe to cover projection between threshold and finished flooring
          2. mencheman | Aug 13, 2009 04:33pm | #10
            thank you again
Two Ways to Test Windows
  • The New Old Colonial
