I will be installing a new pocket door in a new location of a kitchen wall in a remodel next week. I have never done this before, although I have installed numerous prehung doors. Is this much dirrerent than a standard prehung door (other than the jamb/frame is much different)? Should I be looking for something on the rough intall that will make life easier on the final if I do it now? I do know my finished floor height with 3/4” oak.
Thanks for any help1
Barry
B,
Check your floor first. Badly out of level floors may hang up the door or at least look bad if it's a fairly tight fit. Then, try to get your header to be square with the latch side jamb. You'll get some help with adjusting the wheels, so don't make the header out of level if you don't have to. I'd be happy to share some more tips by email if you'd like,
MD
*One big No-No...don't screw or nail off the sheetrock ...kinda embarrisn when you go to close the door!
*B Novick,
View Image © 1999-2000"The first step towards vice is to shroud innocent actions in mystery, and whoever likes to conceal something sooner or later has reason to conceal it." Aristotle
*we discussed pocket doors and differnet methods back in june...look here in the archives.. Adrian Wilson "Pocket Doors" 6/29/00 4:41amand this thread was even better... at least as far as my advice went.... Mike Smith "How best to do Pocket Doors" 4/13/00 11:12am
*Definitely go for the kit. It is faster and easier, especially for the first time. Also, set up the casing so it can come off easily. At some point someone is going to have to get access to adjust the door. Too often that means tearing things up. That isn't a big deal to us. But it is to the homeowner who has a multiday demo and re-rock or such job when all they wanted to do is adjust the pocket door.
*Hi,I also have a pocket door challenge. I have replaced the foundation, but the settling has presented a tricky problem. There is a 48" x 78" pocket door that no longer closes off the living room from the Front Door. At the top the gap is 3"!! No one can believe it until they see it, and I have yet to find someone who has any experience with something like this. The door is heavy but it slides easily until the last few inches. It appears to be original (1918) with no hardware. I have read all threads on pocket doors and wonder if anyone has taken out an original. I would like to keep the original, but may not be able to, and the opening size almost requires a custom solution. Thanks in advance for any ideas.
*May I suggest using only screws, not nails, for all connections? We are not talking new construction here. It will be much easier to unscrew your mistakes. Oh yeah, have a nice dessert waiting when the job is done. Some of these things take half a day.
*I did end up using screws, and it was a good thing after I found out I installed the top track on the bottom of the door frame (OOPS!). I kind of wondered why there were two metal plates covering the track.Anyway, after taking it back apart, I put the whole thing in, including mistake time in about 11/2 hours. I had to tapcon the bottom of the frame to cement slab with radiant heat tubes inside.Barry
*Joe, What's with the groove in the bottom of the door, and, the 2x2 openining on one side? I trim out a lot of these, and am ready to throttle the framers. Spill your guts.Baad BocketsBarry, Plumb and level will make everything later easier.
*BB,
View Image © 1999-2000"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich W. Nietzsche
*If this is your first to do PLAEASE go with the kit next get a small rubber bumper and put it on the inside so when it close's it want tear it self apart in time i have installed and repaired and replaced MANY to date OLDerwere the best when Craftsmen made them up but today go with the kit Barry
*Sally, a teensy weensie 3" gap is no big deal for a Master Boogerer. You obviously haven't called any masters to look at your minor dilema.Go the the local Orange box and pick up a case of stout caulk. I'll be over there in an hour to fix you up.blue
*Hey Novick,The kits are crap.......nuff said. But......if you have never installed a pocket door before, the kit is the way to go. We buy Grant rails and trolleys and build our own. On a 2x6 wall we use tube steel to reinforce the sideways 2x's that make the pocket walls. It makes for a thin but sturdy wall. One builder had us use 1 3/4" s/c slab doors for the walls. Nice touch. Pocket doors are not for the beginner, and I feel should be againt the law.Ed. Williams
*The new steel and wood kits are not crap. Make sure the roller kit for the door has 3-4 rollers that straddle the track. This will eliminate the door from jumping the track. The frame is fastened with the kit on the floor, rail plumb, opened end top screwed to jam/stud. Then fir out from rough cut opening so the back of the door box can be screwed solid to the stud to which the door slams against. Fir out the header and screw it for this carries the weight of the door.Install back rubber bumper stop for door. Use 1" drywall screws to fasten your sheet rock . Install "finished" door, with pull.Trim out opening with 1x2 top first, then pocket trim and then 1x 4 9/16"jam. Good Luck!
*ed. why do you think they should be outlawed?I don't like them, so I'll vote for outlawing them.blue
*thats another vote to outlaw pocket doors. Not as hard but just the same for bypass doors. Only for the reason of them being a royal pain..
I will be installing a new pocket door in a new location of a kitchen wall in a remodel next week. I have never done this before, although I have installed numerous prehung doors. Is this much dirrerent than a standard prehung door (other than the jamb/frame is much different)? Should I be looking for something on the rough intall that will make life easier on the final if I do it now? I do know my finished floor height with 3/4'' oak.
Barry
