Installing Roof Decking: Nails/Screws?
I’m about to start installing 5/8″ OSB with Radiant Barrier and Koolply plywood Decking.
What size nails or type of screws would you use to nail it down? The rafters are on 16″ centers.
Thanks for sharing your experience,
Bill
The manufacturer recommends 8d nails, 6" OC on the edges, 12" OC in the field. There is no need to use screws. If you did, you would have to use mild steel, not hardened, which can be very expensive and time consuming, maybe needing predrilling and countersinking. You can download the installation guidelines here.
http://www.lpcorp.com/radiantbarrier/professionals/installation.aspx
Great, thanks for the help.
Bill
