Installing sleepers on concrete
| Posted in General Discussion on March 17, 2000 10:02am
I always try to isolate lumber from any type of masonry whether it is pressure treated or not. I mean why not? The stuff is cheap. But we have a fairly big bug problem out West. I like to use tar paper, but any isolation membrane will work.
  1. Guest_ | Mar 18, 2000 06:55pm | #4
    I have a job coming up which requires installing treated SYP 2x over an exsisting exterior concrete slab, and adding a access ramp. My question is, should I take the time to use a vapor barrier between the slab and sleeper, or go over top without it.
    1. Guest_ | Mar 16, 2000 01:10am | #1
      *seems like a pretty good idea.
      1. Guest_ | Mar 16, 2000 01:57am | #2
        *Tom Pressure treated lumber is designed to be use in situations where lumber comes in contact with masonry. If you are putting PCT decking over your sleepers, I don't see the need for a vapor barrier. Just Guess'n Shakey Jake
        1. Tommy_Mac | Mar 17, 2000 10:02pm | #3
          *I always try to isolate lumber from any type of masonry whether it is pressure treated or not. I mean why not? The stuff is cheap. But we have a fairly big bug problem out West. I like to use tar paper, but any isolation membrane will work.
          1. Guest_ | Mar 18, 2000 06:55pm | #5
            *Tom,If the application is outside, and you use treated SYP, I don't think the vapor barrier will do any good. I wouldn't worry about it.Ed. Williams
Two Ways to Test Windows
  • The New Old Colonial
