In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Installing “trim beams”
user-173926 | Posted in General Discussion on July 2, 2006 07:47am
I am installing trim beams or feaux beams soon. I’ve already got my 1×6 & 1×8 select cypress in the house & it should be fully acclimated. As everyone probably understands, I need to cut a 45 (or more) degree miter on the edges so that I can create the look of a 16 foot solid cypress beam on the ceiling. My fear is that a less than perfectly straight piece of cypress will wreak havoc on the corners of the finished beam.
I haven’t done this specific job before – I’m open to all suggestions.
    Sphere | Jul 02, 2006 08:13pm | #1
    That is a tuff row to hoe right there.
    I'd be inclined to parallel rip and then use a router with a lock miter bit. Trying this on a table saw will NOT give you the results you are shooting for. I can almost see what will result. GAPS.
    Clamping up is another challange, that the lock miter will help with, it self registers.
    Easiest in my book is glue it up in a [_]  and flush trim after the glue is set, skip the miters altogether.
    There is no cure for stupid. R. White.
    1. user-173926 | Jul 05, 2006 05:05am | #8
      Thanks for your reply, but.... what is a lock miter bit? I've not found one yet.
        Sphere | Jul 05, 2006 05:08am | #9
        http://WWW.ROUTERBITS.COM http://www.routerbits.com/cgi-routerbits/sr.cgi?1152065254_4188+74
  2. Jer | Jul 02, 2006 09:15pm | #2
    I just did a big job of wrapping beams.  I did it exactly the way Shere said except I was using clear white pine that I selected myself, a much straighter and more stable wood.  The result was really incredible, you cannot see any seam whatsoever.  Your problem is that you are using cypress and I don't know how straight the wood is.  I did everything, glue up and all, in the shop on a long workbench using about every clamp I own (100 plus).
    If the cypress is squirrelly, I would butt joint and clamp the hell out of it, then trim it, all at the bench making a large sleeve.  Prefinish it, cut your ends accordingly and install angle screwing down from the top of the rough beam.  Good luck.
  3. Phat | Jul 02, 2006 09:25pm | #3
    I've never tried this for this application, but... perhaps making a very stable template and using a router with a 45 degree bit.
    Never underestimate your ability to overestimate your ability
  4. RW | Jul 02, 2006 09:37pm | #4
    Perhaps because of the difficulty of making a miter line up over a great length, a number of beams I see in old houses didn't use a miter. They used butts, and again probably to keep them from looking ugly, accentuated the thing by having a reveal.
    In practice, I set the router with a 3/4" bit about 3/8" deep and leaving a 1/4" reveal and plow dados. The first side member goes up, scribed if necessary (like if it isnt covered by crown) and tacked, just enough to hold, to the layout lines. But not so much I cant tweak it later. Then I set the bottom in the dado, clamp the heck out of it and shoot brads in from the side. Then the other side goes up, mostly holding everything with clamps, make sure its all square to the world, and nail it off. So the bottom sits 1/4" into the beam, leaving a little lip on the side members at the bottom. Looks nice.
    pic - not on a celing, but shows what I'm saying
    "Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
      jhausch | Jul 05, 2006 05:42pm | #12
      Hijack alert -
      That's an interesting detail.  do you have any more pics of that job?
      I am building a place where the greatroom will have a 17' flat clg.  There will also be a loft in part of the room, so a beam like your pic would be visible from above.
       I was thinking about doing a coffered look and putting cans in the "beams"; however, I may try something like your pic.
      http://jhausch.blogspot.comAdventures in Home BuildingAn online journal covering the preparation and construction of our new home.
  5. Shep | Jul 02, 2006 11:07pm | #5
    Another vote for the lock miter.
    It takes a bit of fussing and time to set up, and it should be done on a router table or shaper.
    But for invisible joints, and (fairly ) easy glue-up, it can't be beat.
  6. Danusan11 | Jul 03, 2006 02:12am | #6
    You can go with the lock miter or I have in the past ripped to a 47degree and used gorilla glue and pin nails. Where you don't get a prefect edge you can burnish it over. Also add triangles to inside for nailers.
  7. Sojourner | Jul 03, 2006 03:33am | #7
    I've made genuine authentic fake beams myself using the same sized dimensional lumber as you're proposing, though it was pine rather than cypress.
    I first tried to miter the corners on the tablesaw, and I was just not happy with it due to the gapping, even though it was slight. I eventuallly went with the reveal method much as like described in RW's post. I had lagged a 2 x 6 up to the ceiling (into the joist), and then installed the sides, and then blocking/spacers to attach the bottom and set the reveal.
    Sixteen feet is a long way to go to match miters up . . .
    Good luck,
    sojourner
  8. piko | Jul 05, 2006 08:18am | #10
    Without knowing whether you want and antique or modern look, I'll plump for the former, and suggest that many old beams have a chamfered edge. IIWM I'd chamfer down to almost the thickness of the lumber, so that there's an absolute minimum of the original edge showing, then butt and glue up (probably with a glued strip nailed fron inside, too). Don't chamfer within the last foot of each end to give the impression of it hewn from a tree.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
  9. calvin | Jul 05, 2006 01:18pm | #11
    mud,  if all I had was a circ. saw and a decent ripguide.  I'd rip the 45's on all the pcs, glue up and pin them starting at one end.  To keep the boards from spreading while fastening I'd tack two strips of wood to a work surface.  Working from the top so you can see the seam, adjusting as necessary.  When you've got one edge assembled, take the side of your wood handled hammer (up near the head) and roll it along the sharp mitre.  This will ease the edge, but will also close up the joint.  You and a helper install.  If working alone, I'd probably put the bottom pc. up into position first, then add the sides, bashing the crap out of it with a block to get the good fit.  Sand the joints soon, sawdust further closes the joint.
    Quittin' Time
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
