insulate attic under floored storage
| Posted in Energy, Heating & Insulation on April 3, 2003 04:50am
I want to floor a portion of my attic so I can use it for misc. household storage.  I want to insulate under the flooring so I will retain the recommended R-38 value but the ceiling joist depth is not sufficient to use fiberglass batts, etc.
Is there any reason that I can not use a foam board made of polyisocyanurate material under the plywood flooring to get the R-38 value I need?
  1. xMikeSmith | Apr 03, 2003 06:48am | #1
    take up the attic flooring and cross the joists with whatever you need  to get the depth you want...
    say you have 2x6 attic joists .. cross them with 2x6  and now you have a 12 inch floor system.. insulate to suit
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
  2. IronHelix | Apr 03, 2003 12:35pm | #2
    If it is a trussed roof system please check out the loading specs before adding more materials.  Then ask how much  storage weight will be okay!
    No matter trussed or stick framed when you begin to load an attic with junque check out the spans and joist size for possible problems with added weight.
    ........................Iron Helix
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
