FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Insulating a basement
lester | Posted in General Discussion on November 1, 2006 04:26am
I live in pei canada,where it’s cold 5 months of the year. any thoughts on insulation and using a vapor barrier in a basement?
  1. darrel | Nov 01, 2006 04:46am | #1
    There are a lot of opinions on how to insulate a basement, though the concensus seems to be closer and closer to this:
    1) Make sure all your water problems are adequately addressed first.
    2) Use EPS or XPS from floor to ceiling, fully sealed/taped.
    3) Don't use any other vapor barrier.
    The concept is that the EPS/XPS acts as a vapor retarder. It should prevent summer condensation, yet breaths 'enough' to eventually let any trapped condensation dry to the inside.
    Alas, at least around here, this concensus goes against building codes. Around here, they ask that you use a full vapor barrier from ceiling to floor. And this is in 100 year old houses that no amount of landscaping can make fully dry. Needless to say, I smell a lot of musty finished basements around here.
  2. maj | Nov 01, 2006 05:20am | #2
    Whichever way you decide to do it, because you will no doubt get conflicting ideas on this one, don't use fiberglass batts without some type of vapor barrier between it and the foundation. Rigid foam (XPS) is the best solution. Again, there are many options this way also.
    I have done it several different ways. I like a 2x4 studded wall out 2" from the foundation with 1" XPS nailed on the backside of the studwall. This is done while laying on the floor, before tipping up the wall. This gives you a 1" airspace between foundation and the foamed wall. Any moisture (vapor) in the foundation is still able to dry with that airspace.  I then install R13 friction fit batts in the stud bays. NO VAPOR BARRIER on the inside of the studwall.
  3. Reg | Nov 01, 2006 03:38pm | #3
    No Vapor Barrier on the interior goes against "accepted practice" but makes sense when one thinks about it. Walls (including foundation walls) must be able to dry out, so moisture must be able to escape in atleast one direction. Given that the surrounding soil is typically moist, wall moisture cannot escape in that direction.
    The principles are explained well by Joseph Lstiburek (Building Science Corp.) in his book "Builder's Guide to Cold Climates". Isn't he Canadian?
    Randy
Double Dormer Transformation
This historic schoolhouse was transformed into a stunning four-bed, three-bath home with ocean views and a modern open-concept design.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • Code Check Complete 3rd Edition
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
