I am going to club a basement in a new home. There is existing insulation nailed to the concrete walls. It has a foil facing and I am not sure what the R-value is. Can this insulation be utilized? Do I need additional insulation and if so, should it be faced? Like a lot of you, I worry about moisture and mold. Thanks for your help.
Does "club" mean you're going to finish it?
If the existing insulation is foil-faced (vapor barrier), any insulation you add to it must be unfaced (no vapor barrier) - otherwise you are creating a cavity that moisture can't escape from.
Any more details for us? what type of insulation is nailed to the wall? I will assume rigid foam of some sort?
How are you planning to put up the walls? furring strips? studs?
Will the basement be tied into the existing HVAC system?
Justin Fink - FHB Editorial
Your Friendly Neighborhood Moderator
