Insulating Concrete ceiling slab
Genoa | Posted in Construction Techniques on April 18, 2007 06:05am
A 16′ by 32′ basement room has an engineered concrete slab ceiling that forms the floor of the garage above. No supports within the open space.
It is storage space, not living space, but would be nice to insulate at least moderately from the varying garage temperatures to provide more even seasonal storage temperatures.
Are there any systems out there?
2″ extruded foam panel glued in place? Nailed through furring strips (which would allow drywall to be attached – though that would heavily weigh the connections).
Thanks for your help!
    BillHartmann | Apr 18, 2007 10:40pm | #1
    If I was building now I would use ICF decking system.
    I have office and shop space under my garage.
    In the office I glued blue board and then glued ceiling tiles to that.
  2. IronHelix | Apr 18, 2007 10:46pm | #2
    Yes, insulating the slab would moderate the temps in the storeroom area...even reduce potential moisture condensation on the slab's cold surface.
    Please consider a spray-on close cell foam to accomplish your needs.  In my area it is quite cost effective.  Check your yellow pages for insulation/insulators/foam, and get a price quote for 2" od spray-on!
    ...............Iron Helix
    tkiser | Apr 19, 2007 03:31am | #3
    I use a product called http://www.insul-deck.org check it out
    1. Genoa | Apr 19, 2007 03:35am | #4
      Thanks. That looks like a product for new construction, not for insulating my pre-existing slab ceiling. (Let me know if I am mistaken)
  4. IdahoDon | Apr 19, 2007 04:02am | #5
    Gluing rigid foam is probably the best choice we've come across other than having it sprayed on.
    We're in the process of doing the same as you.
    Cheers
Choosing a Paintbrush
  • The New Old Colonial
