insulating floor of building on piers
rockon | Posted in Energy, Heating & Insulation on October 8, 2006 08:55am
I have two small projects that need floors insulated. I’ve used fiberglass, vapor barrier up, held by chicken wire, but then you’re open to insects and mice. I’m looking for a solution that won’t  cause a moisture problem.Expense is also a concern. Thanks,rockon
  1. peedee | Oct 11, 2006 08:57pm | #1
    I have used (and removed) a product that was app 5/8" thick sold in panels like plywood but was of a much lighter density/ weight. It could be used to reduce convection transfers and/ or simply to shield FB from insects/ rodent incursions. I can't recall the name of it (CRS disease, damn!) but I expect a decent local HI store could identify the product.
    Not that rodents _couldn't_ chew through this, they could and might, in which case the only other solution I can think of that's reasonably affordable would be something like 1/4" ply (I expect some people would argue rodents can chew through that too but it's pretty uncommon in my experience). More on rodent issues, they're usually looking for either a) food/ water (in which case eliminating the sources is an idea), or b) a place to nest (in which case eliminating them is a common option).
Fine Homebuilding – July 2023, Issue #316
Find online articles on timber-framed solar canopies; the right footings; the best toilets; choosing insulation; compact cordless routers; and much more.
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
  • The Right Footings for Strong Foundations
  • Tool Test: Compact Cordless Routers
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
