Have a fairly long run on a hot water circulation system.
Any thoughts on the best possible insulation products. I’m aware of most types of insulation, I’m specifically looking for the best brands.
Thanks for any advice.
In issue #314, Fine Homebuilding published an article titled “The End of Deep Energy Retrofits” by Rachel White of Byggmeister. The premise was that deep energy retrofits are not as…
The best stuff is what is used on most commercial projects.
Fiberglass
http://www.owenscorning.com/comminsul/products.asp?product=273&system=83
I don't know that the brand is critical.
You can always use armorflex which is what is sold at the big box stores and is what is used on most residential stuff.
But, you asked for the best. The fiberglass is naturally the most expensive and the most time consuming to install. You should by the prefab elbows and the white tape to get a truly professional looking job.
carpenter in transition
