Insulating the attic
jr40 | Posted in General Discussion on July 31, 2008 12:03pm
Being “real” energy alert now, I am wondering if I should consider adding rigid foam under the roof sheating between rafters.  My attic is now at around R50.  The roof is thick butt cedar shingles.  Has anyone done such a thing?  Does it work?  What effect will it have on the wood shingles?  Thanks.
  1. MSA1 | Jul 31, 2008 12:17am | #1
    Not a pro at this, but I dont see any benefit from insulating the rafters. The insulation on the attic floor makes it an unconditioned space and because of that you're not gonna accomplish much by insulating the rafters.
    You have R-50 on the floor I think you may be well covered.
    1. jr40 | Jul 31, 2008 04:33am | #4
      Thanks for the note.  I've read so much about using foam between rafters on super energy efficient homes that I'm thinking I'm missing something.
      1. frenchy | Jul 31, 2008 04:11pm | #8
        jr40
          Let me see if I can make things clear for you.
         Most attics are uncondtioned spaces.. they are insulated from heat loss by the insulation on the floor. At the edge of the attic under the eves usually are vent holes designed to help prevent ice dams and prolong the life of your shingles..
         If however your attic is completely sealed up added insulation under your shingles  won't hurt.  It's not the most effective but it won't help much.  Sort of like going from R50 to R75 not really cost effective..
           Look up Hot roof versis cold roof if you'd like it explained more completely. Or just ask here..
          Dinosaur | Aug 01, 2008 04:12am | #9
          Oh, no! Not hot-roof/cold-roof AGAIN...! I haven't got my Nomex suit back from the dry cleaners yet!
          LOL....
          http://forums.taunton.com/tp-breaktime/messages?msg=106537.1
          That thread has a fairly comprehensive explanation of the physics of roof ventilating, plus some scary photos of what happens when you don't. (Plus some nasty flamethrowing from another source, LOL, but whaddya expect....)
          Dinosaur
          1. Piffin | Aug 02, 2008 11:09pm | #10
            so did you finally realize you were wrong?;)BTW, I have been looking right thru your flameup signature file since it had been here for so long, but recently started looking at it again. Seems like I see a face in the explosion befor ethe cloud goes up. Is that the diabolical face of a former spouse I see?
            Dinosaur | Aug 03, 2008 05:15am | #11
            No, that's a pic of Sauron in a bad mood. X isn't that pleasant looking.
            Dinosaur
        2. jr40 | Aug 05, 2008 12:02am | #12
          Thanks, that was a great help.  I feel O.K with my current insulation set.
            Matt | Aug 05, 2008 04:05am | #13
            Here is something else to think about... assuming you have forced air, I wonder how leaky your duct system is?
          2. jr40 | Aug 05, 2008 05:02am | #14
            I have tried to tape as many connections as I could.  In the attic, my ductwork is insulated flexible 6" tubing.  I have tried to reduce the number of bends and curls as possible and go for the straightest lines to the vent opening into the ceilings.  I wrapped the rectangular 8 x 10 ducts in the crawlspace with 1"insulation fiberglass....That reminds me of another question.  In a new addition, 20' x 16', over a crawl space, the contractor did not place any foundation vents.  The foundation is block wall, not poured.  Shouldn't I be thinking about venting that space somehow?
            Matt | Aug 05, 2008 02:13pm | #15
            With the duct leakage, the best way to address that is with duct mastic.  It comes in a 1 gallon can and you paint it on.  It's like a paste.
            Regarding the addition crawl space, it either needs to have the ceiling (house floor) insulated and have foundation vents or it needs to have the block walls insulated (no vents) and some conditioned air from the HVAC being pumped into there.  In either case the CS dirt floor needs to be 100% covered with a vapor barrier.  In the case of the non-vented crawl the vapor barrier becomes even more important so the VB seams must be sealed and it needs to be glued to the CS walls.  With this "sealed crawl space" the area must be perfectly dry.  6 mil black polyethylene is the default VB but there are other, better products out there which are more expensive.  If the CS floor happens to be covered with concrete, it still needs the plastic - weather above or below the concrete.
            Proper treatment of the CS is not so much an energy saving thing as it is just a "healthy house" thing.  Moisture can build up down there and cause the floor system lumber to rot and mold and fungus can grow down there.
            To learn more about "sealed crawl spaces", also known as "conditioned crawl spaces" go to the Building Science Corp web site.  They have great info on energy savings too.  Don't fall to hard for their hard sell though.  Although they have some great ideas their way is not the only way.
          4. jr40 | Aug 05, 2008 05:43pm | #16
            Thanks for all the excellent information.  I have plastic vapor barrier on the dirt and the walls are covered with glued on 1" foam board.  I cut through the original house poured wall into the crawl to add HVAC ducts.  The opening is about 4" wider than the ductwork (8 X 10).  I am going to get busy with your information in mind.  Thanks again.  You are very helpful.
  2. DanH | Jul 31, 2008 12:22am | #2
    I'd agree with MSA1. Put the effort into other things, such as making sure all penetrations of the ceiling are sealed, removing window trim and foaming around windows (low-expansion foam please!), etc.
    It is an ironic habit of human beings to run faster when we have lost our way. --Rollo May
    1. jr40 | Jul 31, 2008 04:36am | #5
      I used fiberglass insulation around the windows when I built the house.  Would foam work better or am I good with the fiberglass tucked in the spaces?  I have foamed around the penetrations of electric, and around the furnuce flue, fireplace, etc.  Hope that works this winter as well.
      1. DanH | Jul 31, 2008 05:41am | #7
        You're probably good, if it's tucked reasonably tight.
    Dinosaur | Jul 31, 2008 02:30am | #3
    It would help if you'd fill in your profile so we'd know where you are located. The answers to a lot of questions like this depend on the climate.
    Dinosaur
    foolish men call Justice....
    1. jr40 | Jul 31, 2008 04:38am | #6
      Thanks Dino, this is Springfield, Il where the winters get pretty cold but not so bad as 200 mi. north of here.
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
