Insulation redo?
jvoorhies | Posted in Energy, Heating & Insulation on March 15, 2007 05:09am
We recently bought a one-story ranch house with a full basement (half finished, half garage). Standard 2×4 external wall construction filled with fiberglass batts, fully insulated under the main floor with more fiberglass batts, and the attic filled with blown-in fiberglass – looks like 6 to 8 inches deep up there. Roughly 1800 sq. ft. upstairs & 600 finished downstairs. Vinyl siding exterior, vinyl-trimmed double-pane windows. Middle Tennessee location, so the winters aren’t horrible but it isn’t Ft. Myers either.
The problem is that the last house, which I built, had 2×6 walls with an extra 1″ of Styrofoam over the fiberglass so I’m used to way lower heating bills. Last month, a cold one here, the gas bill for the new house was $285, double the prior month.
What can I do to improve the insulation? Would it help if I insulate the interior walls of the entire basement? Pull the floor insulation & replace with spray-in? I saw in another thread that pulling the siding and adding an inch of foamboard wasn’t going to be all that helpful, so any ideas will be greatly appreciated.
Thanks!
  1. IdahoDon | Mar 16, 2007 06:46am | #1
    There's no question that the first place to upgrade should be the attic.  Nothing is less per R-value than blowing in more attic insulation.  We're in a mixed climate and still try to get R-60 up top on all projects.  Then look at the other areas that are harder to get to.
    Prior to adding the new fluffy stuff dig around with a foam can and fill any and all holes coming or going from the crawlspace, attic, and anywhere you can reach.  Caulk thin gaps.
    Good insulating!
    1. DaveRicheson | Mar 16, 2007 01:01pm | #3
      You da man!
  2. objector1 | Mar 16, 2007 07:13am | #2
    You need more insulation in the attic. Probably 80% of heat loss occurs there. Measure the depth of the insulation in the attic and add to at least the level of 13 inches. Adding 6 inches of blown in will cost about $500.00.
  3. Piffin | Mar 16, 2007 01:11pm | #4
    I'd start by having an energy assessment and blower door test done to find out where the infiltration leaks are. Controling infiltration can save 30% with a small amt of work and most older homes have far more infiltration than occupants are aware of.
    So objectively foinding out what the weakspots are to adress first would be more efficient than willy-nilly throwing a bunch of insulation at the place.
    But I would plan on adding up to a total of about 15" of the chopped FG in the attic.
    1. jvoorhies | Mar 16, 2007 03:47pm | #5
      Sensible ideas. Thanks for the advice!
Use a Press Tool for Plumbing Connections
The Milwaukee M12 press tool has become a popular alternative to soldering copper for plumbing connections.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
